Home > Maintenance & Modifications > Brown rear demister element |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
Mine is brown and the top 2 elements have failed, going to get it looked at when it goes in for a service later this month.
9th Mar 2011 4:06pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
it's just discouleration due to the heat 2.4 90 XS
10th Mar 2011 4:24am |
That's interesting my top two elements don't work either. It will go in to the dealer to be sorted out
10th Mar 2011 6:54am |
The wires are made with silver mix.
The heat developed from the wires make oxidation on itself Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
10th Mar 2011 7:49am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2039 |
Could be that the high level brake light rubs on the elements and wears it away!
10th Mar 2011 8:43am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
The top two stop for that reason - there is a fix for it! Mike
10th Mar 2011 4:42pm |
Absolutely not..... but there is another problem.......... The problem is the 3rd stop tail rubber piece, probably it release rubber solvent that "eat" the heated element Dealer changed me the rear windows two times. Now I cutted (below) the rubber (5 on the figure) and make same sockets (where are 90° tracks curves and stop carries) for avoid contacts from the heating tracks and the rubber. Now the problem IS solved... Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
10th Mar 2011 5:23pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Mine has failed too... I noticed the other day, thought that I was seeing things.
10th Mar 2011 7:44pm |
Both my heated rear screen element and the high level brake light element on the glass are broken.
I had to run a wire up from the connector on the bottom right of the glass to to the high level brake light to get it to work. Last edited by DAZ110 on 11th Mar 2011 9:12am. Edited 1 time in total |
10th Mar 2011 9:01pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Interesting.
had my rear window replaced under warranty. no questions, no drama. also had my front screen changed as it was de-misting unevenly, left a strip down the middle of the drver side until last. now fine. very impressed by the warranty service but by the sounds of it it seems a common problem on the rear window BM52 |
10th Mar 2011 10:09pm |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 |
Hmm, my top two elements have failed as well, I mentioned it to my dealer who made a big thing of saying 'as it's for you sir, we will simply change the whole rear screen, just bring it in'. Perhaps they were not quite as generous as I first thought!!
10th Mar 2011 10:25pm |
as I posted many moons ago put some insulating tape on the 'rubbed' area to prevent it happening again 2.4 90 XS
11th Mar 2011 9:51am |
