Home > Maintenance & Modifications > Work Lights - What have you got?? |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
My setup is just two LED units I bought from the local Lorry Drivers accessories type place. They are £25 each and are LED and are rather bright (12W each).
http://www.ksccuk.co.uk/shop-page/45882049...p/10032050 Click image to enlarge |
10th Jun 2017 11:03am |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
arran,
far corners make a number plate light plinth that you can bolt a work light on to. search their website |
8th Aug 2017 11:22am |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 726 |
Found it..
Thanks giles |
8th Aug 2017 3:08pm |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 |
Click image to enlarge That's what I ended up doing! Brilliant! Click image to enlarge 2010 Defender 90 HT The longer I live..... The better I was! |
8th Aug 2017 3:18pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
I have a very bright LED Work light fitted; I also connected it to the reversing light. Soon after I had to disconnect it as when pulling up to reverse park on roads I was blinding the motorists behind me, some of whom were rather annoyed with me.
I then wired the light to the reverse light circuit with an on off switch so now no more road rage incidents. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
8th Aug 2017 3:32pm |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 |
S17 with the same remote as Vee Tee, great if wired with a switch in the cab, we leave it switched on & turn it off via the remote so when in the RTT in remote places we can turn the light on via the remote brilliant!
8th Aug 2017 7:24pm |
A single S17 at the rear of the truck. Night test results.
1. In the off position. Click image to enlarge 2. In the on position. Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
9th Aug 2017 4:29am |
