![]() | Home > Wheels & Tyres > Sawtooth alloys |
Teario Member Since: 04 Aug 2015 Location: Merseyside Posts: 153 ![]() ![]() |
I also found the whole thin/thick spoke thing confusing. I recently ended up with some different sets though and here's what I found.
The first set I ordered looked like this: ![]() Click image to enlarge ![]() Click image to enlarge They were damaged so sent them back and used a different supplier to get a replacement set. The other supplier was more expensive so I ended up only buying 4. I was too impatient to wait until I'd saved up for the 5th. They are now on the defender and look like this: ![]() Click image to enlarge Despite ordering grey, the second supplier sent me black ones. I liked them though so kept them. You can see in the curve that they are thicker. I assume this is what people are concerned about. It's really noticeable once you spot it. Later, I ordered a 5th from the same supplier. This one is different to the 4 they sent me the first time around though. I use it as the spare: ![]() Click image to enlarge ![]() Click image to enlarge This new one also has a thin curve, which was unexpected because I assumed it would match the 4 that I got from them a few weeks earlier. Worth noting is that the inner "dish" part of the spoke (as if you're looking from the inner side of the wheel) on the "thin" spoke is also shallower. I don't have pictures to illustrate this though. There are some other differences too. I'm not sure if they grey ones were shallower or it's just an illusion because the centre cap part protrudes further. ![]() Click image to enlarge The 4 black ones I got have a load rating of 1250. Or maybe 975. Depends which one of these you choose to believe. ![]() Click image to enlarge The 4 I received on my first order are also very slightly different in size compared to the 5th. ![]() Click image to enlarge The original grey ones I didn't get the product code of, but the first 4 black are A16516533XTECHA and the 5th is A16516533XTECH, so basically the same without the "A" at the end. Hope that helps and doesn't just leave you more confused ![]() |
Gutch1985 Member Since: 15 Dec 2015 Location: Yorkshire Posts: 105 ![]() ![]() |
Mate that is brill as I now no the difference but that has
No problem. I've got some more pictures here: https://drive.google.com/open?id=0B9CtoihBHxZIOEcwcWhCSXVJUkU
Should also mention mine are 16". Good option might be to get to a show and you'll be able to see them properly. I couldn't decide between 16 or 18 so went to GBLRS and there was a bearmach show car with 16s on that I had a good poke around. Since I got both types from the same supplier, if you do find yourself concerned about the spoke issue you'd do well to clarify with the place you buy from about which type you're going to receive. |
Yeah I had 16" gen ones on my 90 but then went for 20 mantas on my 110 but the drive isn't as nice. So did some reading up and it's sounds like the 18" have best of both worlds.
