Home > Maintenance & Modifications > Transfer box oil change
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Ciao,
Just changed the oil in the transfer box. I was surprised to see the amount of metal on the magnetic drain plug. The vehicle is only 2 years old as wel.
I have never used a magnetic drain plug on a transfer box before so I'm unsure if this is normal on a first oil change?
Your thoughts or experiences appreciated.
Yan
Post #629951 8th Jun 2017 2:17pm
X4SKP
Hello Yannis
This was mine at 30K...'clean' (first change).
I wouldn't be worried at yours, it's done it's job, there will probably be very little build up from now on.
How many miles... Question
Was there the correct amount of oil in there... Question
Good Luck SKIP
Post #629960 8th Jun 2017 2:48pm
Yannis
This was first change at 18,000 miles and there was about 200ml less oil than there should have been, but I have heard this is common.
Post #629966 8th Jun 2017 3:11pm
gilarion
I have changed the oil on the transfer box many times on various Defenders and I have never had more than a few tiny fragments of metal on the magnetic plug, nothing like your photo. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #629994 8th Jun 2017 5:24pm
Yannis
Along with the fragments in the photo was a sort of metallic sludge all around the bottom of the magnet. . I'm not sure what it could be from or if I should be worried, but as X4SKP said, the plug has done its job, I just wonder what all the fragments are from.
Post #630021 8th Jun 2017 7:15pm
Mo Murphy
From the contents of the transfer box bedding in to one and other I'd imagine. I wouldn't be in the least bit concerned by that on the first change but I would be by the fifth change.
50 Shades of Pennine Grey
Post #630054 8th Jun 2017 9:38pm
miker
I don't know specifically about transfer boxes, but I'd be inclined to agree about things bedding in etc on the first oil change.
Post #630077 9th Jun 2017 12:29am
WeiB.beer
United Kingdom 2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
I changed all my oils and filters over the past couple I weekends.
On my 1yr old 110 Heritage (21,000km) the transfer case drain plug was exactly the same. Transfer case was 600ml short on oil from the factory.
The front diff is definitely harder on the oil than the rear diff, quite a difference in colour.
I used....
Castrol EPX 80-90 for the diffs.
Motul 8100 for the engine oil.
Motul Gear 300 for the gearbox and transfer case.
All genuine oil, fuel and air filters. 2015 110 Defender Heritage Utility Station Wagon
2014 B8 Audi RS4
2003 Audi A2 1.4 Tdi
Post #630191 9th Jun 2017 1:05pm
rallysteve
Front diff oil will always be a darker colour than the rear diff oil as some swivel/CV grease will leak past the swivel seal into the axle case during normal use.
Post #630198 9th Jun 2017 1:17pm
srod
This was mine at about 86k, shortly after acquiring the truck a couple of years ago. No idea how long since the last change. Look closely you can see what looks like the small bits of copper. Guessing maybe previously someone has mistakenly stuck a copper washer on the end of the plug, having nowhere to go it had been rattling around inside the box and been chewed up!
Recently changed again at 108K and there was maybe less than half what's in that picture, wish I'd taken a taken a photo.
For comparison here's my gearbox plug at 86k:
and again at 108k:
Wearing away nicely I guess!
Post #630205 9th Jun 2017 2:06pm
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Sorry to resurrect an old thread, but, when replacing the Transfer Box oil do you replace the copper washer?
And if so, what's the part number? Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #670496 12th Dec 2017 12:39pm
dorsetsmith
FRC4808
Post #670498 12th Dec 2017 12:45pm
bogwert
Wicked! Thank you!! Thumbs Up Chris
Post #670500 12th Dec 2017 12:50pm
Yannis
Change number two at 32,000 miles
Compared to change number one at around 20,000 miles
Seems to have improved, but there is still something going on in there...
Post #764092 17th Mar 2019 10:25pm
