![]() | Home > My Defender > Puma 130 |
bcarlin Member Since: 24 Sep 2011 Location: lanarkshire Posts: 290 ![]() ![]() |
what is the load rating of the boosts? rear axle weight is 2200kgs
950, or maybe 975 comes to mind. Regardless though, the reason Land Rover never offered them on the 130 is that they're not rated for the GVW.
As far as I know, Blindos are the only Land Rover alloy that would be up to the job but there may be aftermarket wheels that would also do. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
I don't think Blindos are offered by Land Rover. They are as aftermarket as any. You could also consider the Evo Corse version (sold in UK as Terrafirma Dakar), which are often used by UK military WMIK in place of Blindos? Both look suitably purposeful and are slightly less likely to give you a hernia when fitting them...
You might be right about the Blindos. I know they are specced for specialist military stuff (WIMK, etc) but I guess even those conversions are 'aftermarket'. I guess they're Land Rover approved though, as those sorts of conversion rarely happen in isolation. Darren
I'm sure you're right when allowing for a safety factor, but I've seen Tornado (Freestyle) wheels that are stamped 850kg on the inside. The published load ratings for Blindos are 1550, which suggests that typically, load ratings are not given in relation to total axle weight. Darren
Yes, you're probably right about them being LR approved, although the later WMIKs are not exactly "normal" LR as they have auto boxes and 2.8 TDI motors ... without even considering the honking great gun on top ... ![]() Definitely top-notch wheels either way ![]() I only went for the Dakar's because a set came up (very) locally - didn't even need to use surfaced roads - at an excellent price ![]() |
mi-cap Member Since: 07 Jun 2017 Location: scotland Posts: 11 ![]() ![]() |
I think you get the max axle weight from the vin tag and then half it for each wheel.
Thanks for the help this, my rear axle weight is 2200kgs
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17588 ![]() ![]() ![]() |
You're right, I've looked up the figures I have (which I should have done before posting above of course) and find the following:- Blindos: 1550kg Defender HD steel ("Wolf"), tube type, ANR5593: 2200kg Defender HD steel ("Wolf"), tubeless type, ANR4583: 2200kg Defender steel, tube type, NRC7578: 1241kg Defender steel, tubeless type, ANR4636: 1241kg Defender 130 (early) (Rapier, Snatch 110), ANR1534: 1372kg Disco 1 steel, NTC5193: 1340kg Although I have a considerable amount of information about just about every type of OE wheel used on every type of Landrover, these are the only load ratings I have been able to pin down. On this basis I would expect a Boost or a Deep Dish to be around the 1200kg mark. |
So why can't boosts be fitted ?
As I said above, LR never offered them on the 130 as they're not up to the job. I'm sure I've seen somewhere that they're rated at 9 hundred and something but I can't find the reference now
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Seats getting recovered, bought from ex moor trim, cubby to match and a momo steering wheel
![]() Click image to enlarge ![]() Click image to enlarge |
Seats completed, cubby box in and a momo steering wheel added today
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
