![]() | Home > Td5 > Defender 110 TD5 Noisy Fuel Pump |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Did you bleed it using accelerator pedal procedure?
you may have to do this several times, what make of filter did you fit? The cheap and nasty ones can cause bleeding/trapped air problems. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Just a thought?
You say your filter was leaking, was it the filter, or the housing/pipe work? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
zinczonk Member Since: 07 Jun 2017 Location: london Posts: 5 ![]() ![]() ![]() |
I don't think is was the pipe work as it's not leaking now. I bought this filter
https://www.rimmerbros.co.uk/Item--i-WJN000020P1 Would that be considered a cheap and nasty one? I have bleed it using accelerator pedal procedure more that 20 times? thanks for getting back to me |
If everything was fine before hand I'm sure it's just trapped air somewhere,
More sinister things like pump, pressure regulator, head, injector seals, would cause this But as yours has only started just after changing filter I think you could rule them out this time? Take it for a good drive, I've had this happen too, and it did finally sort itself out. Did you fill the filter with diesel before fitting? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
It's been on a good drive to Devon and back. No luck.
I didn't fill the filter with fuel before fitting. Could this be it? |
Ok, that was a long enough drive
![]() I would try a different filter before digging any deeper, But there are a few visuals to check first, Have you had a look around the pressure regulator for any signs of leaking? No drips on the floor? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
My fuel pump has always made a noise... haven't noticed any other fuel related problems. I thought they just did this?
Happens as soon as I turn the key, don't notice it over the sound of the engine once it's running. |
