![]() | Home > Technical > rear axle - 90 axle on 110? |
Nige71 Member Since: 05 Jun 2017 Location: bristol Posts: 44 ![]() ![]() ![]() |
Hello All
Will a 1985 defender 90 300tdi rear axle fit 1997 110 v8 . Thanks Nige |
I assume you have the dates the wrong way round, not sure if a 90 axle has a lower load rateing than the 110. Also I think the 110 has a larger rear springs so you would need to change the spring seat. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
There's no such thing as a factory 1985 300tdi, so if that's what you've got then the engine is a retrofit. Regardless though, 90 axles of any vintage are not suitable for a 110 as the latter have bigger springs and heavier duty diffs. Darren
Thanks for the info have not brought the axle yet so will let the bloke know I it won't fit.thanks nige
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6167 ![]() ![]() ![]() |
Might be BS to you... but, if you have an accident/cause on, and the authorities start poking at your truck and realise you've got the "wrong" axle on it, don't come crying here...
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2210 ![]() ![]() ![]() |
There was a fella not too long ago that had "wrong axles" on a 110 (cant quite remember but I think they where Disco axles), something gave way on the rear and sent the 110 to the bottom of a lake with him in it.
Afaik 110s have short nose or salisbury diffs fitted, not long nose diffs which 90s have. So the props probably wouldnt fit. Why not just get the correct axle for your car? That said it is common to fit D2 front axles to challange trucks and the like |
Also, Land Rover didn't develop a stronger axle just for the fun of it
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Is the D2 front axle an upgrade over the normal 110 front axle?...and are they a strait swap? Patrick |
Gilloverland Member Since: 12 Nov 2017 Location: Yorkshire Posts: 61 ![]() ![]() |
I'm aware of that case but the issue wasn't the 'axle' it was the brakes. AFAIK it was a RRC disc brake rear axle but the master cylinder and valves etc had been left original which basically biased the brakes to the rear rather than the front causing a loss of control under heavy braking. Any change from drum brakes to disc on the rear axle (Salisbury / wolf / disco etc) should include the relevant master cylinder. |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1467 ![]() ![]() ![]() |
"Is the D2 front axle an upgrade over the normal 110 front axle? And are they a straight swap?"
Patrick, No the D2 axle is not a straight swap into a 110. The D2 used different radius arms, so it would need some specialist fabrication to modify the axle, or make new radius arms to connect it to the chassis. Also the panhard rod position is different, again needing specialist modification. D2 axles use a different pattern for the hub bolts, that will mean different wheels, front and rear. As some wise people have said above, using the correct type axles for the vehicle is the safest and easiest option for a road vehicle. [/quote] |
Ahh thanks for clearing that up! I couldnt quite remember! |
