![]() | Home > Puma (Tdci) > How long to idle motor before switching off? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
Illegal in South Africa, not sure about other countries? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Declaration, I am not a mechanic, nor do I pretend to be a mechanic so a few questions.
What temperature does the turbo work at? What temperature does oil vapourise at? Does the oil become 'pressurised' in the turbo which could raise the vapourisation temperature. What is the thermal mass of the turbo? Reason being I am struggling to understand that the temperature can cool sufficiently in 10 seconds from being a safe high working temperature to a safer lower switching off temperature. Either those two temperatures are very close together, the thermal mass is small or????? So can someone please explain it to me in simple terms? Or is it nothing to do with temperature but just about letting the turbo 'spin down' gradually under 'controlled' conditions? Yes I am an IT numpity and mechanically inept. Brendan |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4736 ![]() ![]() |
Wait until the wife stops talking-and hope you don't run out of fuel first.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
This tells me again it has to do with lubrication of the bearings, not cooling. (you not gonna cool anything really in 10 seconds). Turbo blades these day's are manufactured from materials that are desighned to withstand high temperature gradients and resist warp. |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i only ever bother when at motor way services, but that could be me trying to get the courage up to face the bloody prices.
