Home > Technical > Rear lights went nuts - SOLVED |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Can top that Heated Rear Window on Rear Brake lights on (but not the High level one) quite fun when a corsa boy is a few inches off the rear bumper flick the HRW on and watch the panick
9th Mar 2011 9:19am |
CarlW Member Since: 21 Sep 2010 Location: Lanarkshire Posts: 53 |
Yes, looks like a bad earth connection MY11 110 XS Station Wagon in Stornoway
9th Mar 2011 4:51pm |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
That should be a factory option |
9th Mar 2011 7:59pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
My radio went off today then came back on and the temp guage went off and i have a speed camera dectector wired to a spare switch next to the radio that only works when the radio is on and the heater fan works with the ignition on 1st position
9th Mar 2011 8:16pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
as already said,check the bulb connectors as these corrode badly and can cause shorting,clean the bulb holder as well then coat in vasaline(not grease as that can contain acids). 2.4 90 XS
10th Mar 2011 4:09am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2429 |
It was the earth connection. Puma 110" SW
10th Mar 2011 10:03am |
