Home > Puma (Tdci) > Engine bay 12V Ignition hook up |
--defender-- Member Since: 22 Apr 2010 Location: South Coast Posts: 90 |
Hi,
I'm about to install some LED replacement Halo head lamp assemblies and I need to find a low ampage switched ignition supply to power the Halo LED rings, ideally in the engine by area. All I can think of is using a piggy-backed blade fuse adaptor in the main fuse panel under the drivers footwell and running a new wire through the bulk-head to the front of he engine bay. Any guidance would be useful please. Zera If it ain't broke don't fix it! |
1st Jun 2017 3:13pm |
Alternator? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
1st Jun 2017 3:18pm |
Hi,
Is that switched by the ignition? Zera If it ain't broke don't fix it! |
1st Jun 2017 3:21pm |
Well, there is only power on the alternator terminal if the engine is is running (and your alternator isn't broken ) ... Cheers, Vincent
1st Jun 2017 3:31pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17475 |
Er, not so, I think! The alternator terminal is connected to the battery +ve, and the battery is full of volts all the time. |
1st Jun 2017 3:40pm |
Oh stupid me yes, you are right.... Every day's a school day. Cheers, Vincent
1st Jun 2017 3:48pm |
Do you have anymore details please? Zera If it ain't broke don't fix it! |
1st Jun 2017 3:59pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2432 |
Excuse my English. In my case the led headlights came with a black (I believe) wire that I just hooked to the (+) wire of the original position lights as you need quite low Amps. Cannot remember the (-) connection. Is that what you are asking? Puma 110" SW
1st Jun 2017 4:08pm |
These are Halo LED lamps and require a 12V ignition feed so the Halo is on when the car is running and also requires a 12v feed from the headlamp relay to disable the Halo running lights when the head lamps are on. Zera If it ain't broke don't fix it! |
2nd Jun 2017 7:27am |
Unless you use a voltage sensing relay or similar device I think you'll have to wire back into the cabin. The feed for the cigarette lighter socket is a popular source for a switched live, although I think it is actually live with the key in the ACC position rather than the IGN position.
Failing that, the CJB is your best source, in which case how you get the feed depends on how much effort you want to put in and how much of the vehicle you want to take apart. The neatest and most "factory" approach is to pop the CJB out and fit a new contact into a suitable position (somewhere where there is an ignition-activated feed on the input side of an unused fuse position), but this is quite involved since it involves removing the dash. Paul Mc on this forum can supply the inserts for the CJB fuseblock. An easier alternative is the plug-in piggy-back connector, which can fit into an existing ignition-activated fuse position and provide a seperate fused feed in parallel to the original. This is by far the easiest approach, and there are several suitable fuses (eg the heated seat fuse). A further possibility, if your Defender had dim-dip and you have disabled it (like all sensible folk do - dim-dip was a ridiculous and stupid idea!) by bypassing the relay, i.e., linking pin 2 to pin 8 on the relay socket, is to take a feed from the now-unused pin 1 position on the relay socket. This is an ignition-activated feed from CJB Fuse 15 (5A). If however your Defender was not built with dim-dip, you may not have this socket wired (I have never looked at a non-DD vehicle to see). |
2nd Jun 2017 8:55am |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
I mounted my DRL controller on the left hand wing.
I routed the 12v trigger wire to the blower immediately adjacent. there is a Orange / red wire from memory that is a ignition live wire. I just tapped into that. The DRL is pulling milliamps, and the blower wiring has plenty of headroom for the additional pull from the DRL controller. All above is fused at source, so really very little risk. Food for thought. Cheers Andy |
2nd Jun 2017 11:31am |
I think the blower feed is also ACC rather then IGN, but I don't suppose it matters at all for this purpose.
Wiper feed may be IGN. |
2nd Jun 2017 11:35am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2531 |
Yes you're correct Blackwolf. I connected my DRL's to the orange feed to the blower and it is definitely ACC and not IGN live. Defender 90XS SW
2nd Jun 2017 11:45am |
Doh.....
Sorry, Cheers Andy |
2nd Jun 2017 11:52am |
