Home > Puma (Tdci) > Rear wiindow brake light glass track connection O/C
--defender--
United Kingdom 2010 Defender 110 Puma 2.4 HT Zermatt Silver
Hi,
I've just discovered that my high level door window brake light was defective. After chasing the fault I found that the 12V switched brake supply to the lamp's 1/4" connection post bonded to the window glass wire track is open circuit. In the short time I've run an fresh wire to the bottom connector of the glass but ideally I'd like to get it fixed.
How can these bonded connections to glass electrical tracks be repaired? I tried cleaning and soldering - no can do...
Zera If it ain't broke don't fix it!
Post #628225 1st Jun 2017 4:20pm
gilarion
You could try this conductive paint from Maplins
http://www.maplin.co.uk/p/electrically-con...aint-n36ba
Or a similar product from Halfodrs
http://www.halfords.com/motoring/paints-bo...ter-repair
The other product you could use to stick the connector back is a Silver Coated/Nickel Filled, Electrically Conductive Adhesives such as those sold by Masterbond.
Or try the many conductive glues sold by RS
http://uk.rs-online.com/web/c/adhesives-se...adhesives/ For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #628237 1st Jun 2017 5:01pm
--defender--
Thanks for the ideas, The terminal is still fully bonded to the tracked glass conductor but not making an electrical connection, I don't want to separate the track from the glass trying to remove it to re-bond it. I'll have a look at the products and see if I can bridge the two (electrically) using some conductive adhesive.
Post #628368 2nd Jun 2017 8:32am
Thon
Apparently this is a common problem - mine has the same issue, but it arose at the MOT because it failed. Luckily the MOT wording is such that if you remove the bulb and fitting then it isn't considered a high level brake light, and hence can't be tested. This is what I did at the time.
With the unreliability of standard defender bulb holders, it seems the high level one suffers similar unreliability but for a different reason. I must get it fixed properly when the opportunity arises, and those suggestions are a good place to start.
Post #628378 2nd Jun 2017 9:17am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
My connector broke off and i cleaned the track with some fine wet and dry 500 and applied a little solder then splayed the wires like fan and pressed them onto the pre soldered track with the soldering iron.
Post #628383 2nd Jun 2017 9:39am
Andrew james
United Kingdom 2015 Defender 110 Puma 2.2 USW Indus Silver
When mine stopped working, tried to solder the connection which wasn't satisfactory. In the end the easiest way to rectify was to get the whole glass unit replaced on the insurance. You only need to pay the excess for glass replacement.
Post #628411 2nd Jun 2017 12:01pm
--defender--
Never thought of that!
Cheers,
Post #628909 4th Jun 2017 5:05pm
