Home > Tdi > 200 tdi gearbox issue
ade666
United Kingdom 2003 Defender 110 Td5 DCPU Belize Green
afternoon
putting this on for a friend he at his wits end
Was wondering if I could pick the brains of all the members for a problem that has developed with my 200tdi 90.
Over the last 6 months I have fitted a new heavy duty clutch, release bearing and clutch release fork. A while later this then caused a failure in the slave cylinder, so I fitted new slave and master cylinder. Once bled up everything was good.
However, over the last fortnight it has been getting harder and harder to get first or reverse, with me having to push quite hard to get 1st, or put up with a grind as it goes into reverse. If I start it in gear with the clutch down I can just feel a bit of drag as if just off the biting point.
I've changed the gearbox ATF as that can make gear selection harder, but that has made no difference. Just fully re-bled the system, no air at all came out.
Does anyone know what may be causing the difficult gear selection?
Thanks in advance.
hope one of you technical geniuses can assist 110 double cab in belize green.
Few little mods here and there
300 tdi disco
Post #628189 1st Jun 2017 1:10pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Thats clutch DRAG, you say heavy duty plate etc, what make ?
Post #628250 1st Jun 2017 5:38pm
Mo Murphy
Did you adjust the pedal height after changing the master cylinder ?
50 Shades of Pennine Grey
Post #628280 1st Jun 2017 7:03pm
ade666
thanks for the replies chaps I shall pass that on too him. I've a feeling he bought a blue box one. 110 double cab in belize green.
300 tdi disco
Post #628360 2nd Jun 2017 6:54am
