![]() | Home > Puma (Tdci) > Broken half shaft |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
How come? I have a rear Diff lock and no probs so far. I use it with caution. Puma 110" SW
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
Bloody hell !!!! what did you do to cause that !!!
I drag lorries on an off site with mine and have been waiting for the bang but never had it yet and mine is proper abused ![]() ![]() ![]() Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
I have had clients break half shafts - Driving up a slippy slope they apply power, too much will induce wheel spin the TC applies the brakes to the spinning wheels = bang goes the drive shafts.
![]() ![]() Safe now with a 130 we dont have TC ![]() ![]() |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
get ashcroft shafts
![]() ![]() 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Then you're just moving the stress point down the line - cv joints. if you uprate those, next stop is the gearbox.. I'd rather break a half shaft than anything else in that chain to be honest. |
it would be diff before gearbox lol as i found out
The half shafts are the easiest 'fues' to change.
exactly |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i always thought that the biggest risk was rebound when climbing, by that i mean, hard accelaration up hill and a wheel looses all traction due to a bounce then as it starts to spin and take all the power it comes back down and gains full traction, like over a tree root or rock, the shock wave of power then pops somthing, usually a half shaft.
no claims that this is fact just my understanding. this is also from the point of view of no axle lockers and no TC. p.s half shafts have been replaced on mine at 40k not due to a conpleate fail but excess movment due to spline damage. |
Which side of the shaft? to the diff or wheel flange? Puma 110" SW
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8223 ![]() ![]() ![]() |
its true you do move the stress point to other elements but they tend to be stronger as you go up the line anyway.
i have had no problems with gearbox or T boxes running 37" Fedimas on ashcrofts with ARBs front and rear for 5 years. and its been used hard. But then Tc broke a std shaft at work on a puma! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
It is, you're right. You can break them in other ways too but the most common is shock loading. |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 ![]() ![]() ![]() |
Thats why I put a switch on the TC, I noticed the axle tramp on the ninty a couple of months ago driving up some big sand dunes. I think an air locker or two and turning the TC of is the way to go.
Allan |
shock loading, thats the phrase ![]() |
