Home > Puma (Tdci) > Request for picture of the ERG valve fitted in a Puma 2.2
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
As topick states. I see faut codes related to the ERG valve. Is there a possability I mounted it in the wrong way?
Regards
Q.
Post #627922 31st May 2017 9:57am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
You would be pretty clever to put one on the wrong way!
They are bad enough to put on the right way... Evil or Very Mad
I could take a photo, but in all honesty you won't see much?
They are buried deep on the 2.2 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #627952 31st May 2017 12:01pm
TopQ1967
the actuator that is bolted with 4 screws can be put in in different directions... think it is now the right way in, but you never know.
I have strange faults and am looking backwards every step I made.
Is the connector in line (facing forward) with the engine, or is it square to the engine (facing to the outside)?
Post #627964 31st May 2017 12:25pm
