Home > Puma (Tdci) > Left pull while braking |
Will probably be a brake caliper sticking. Chances are the right one is partially seized up, so its dragging on the disc when you release the brakes and when you apply them the left hand one is doing all the work.
I had the same on mine, i put a couple of new AP callipers on it, problem cured. Sold the old ones on ebay for someone else to refurb. I think the new Callipers where about £80 each and i sold my old ones for £60 a pair. You can get new pistons and seals for them, and rebuild them yourself, but for me it was quicker to just change the callipers as i needed the car off the road for the least time possible. Britpart do callipers for about £40 each, no idea what they're like. |
30th May 2017 10:52am |
macandy13 Member Since: 25 Dec 2016 Location: Fife Posts: 24 |
I thought it might have been something like that 😕
Do you happen to have part numbers? Preferably for the standard vented calipers. Might as well do the discs and pads while I'm at it. Cheers |
30th May 2017 11:08am |
I did the pads too, if ones been sticking then chances are they're worn unevenly.
The discs are quite a big job on a Defender compared to more modern cars so if there's nothing wrong with them they're best left. SEB500460G for the Righthand calliper SEB500470G for the Lefthand calliper |
30th May 2017 11:12am |
Thanks, I'll look in to it
30th May 2017 12:21pm |
New AP vented calipers ordered, pad retention kit and Pagid vented discs/pads. Bout to order some braided hoses.
31st May 2017 8:08am |
