Home > Tdi > R380 300 tdi gear box mounts
Procta
has anyone ever replaced these? if so can you lads give me some tips?
My mot tester said that mine are Censored practically, and are causing some trouble for the setup. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #627284 28th May 2017 1:26am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
These can either be a pain or easy to do, the best way is to support it on a jack, loosen everything off to free the mounts, raising/lowering as needed. The rebuild is the same everything together loose and then have fun trying to align it al. It's not a hard job but can test the patience for some people.
Take your time with plenty of brews and you will be fine. Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #627309 28th May 2017 8:19am
Procta
Thanks mash, looks like its a weekend job and a half then. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #627398 28th May 2017 6:37pm
oneten110
The genuine mounts are quite soft so it is possible to manhandle them a bit to get them into position, watch out for the razor sharp edges of the heat shield on the exhaust side mounting though.
Post #645696 22nd Aug 2017 5:18pm
