![]() | Home > Td5 > kangarooing TD5 |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Could be a boost leak.
martindavis Member Since: 10 Nov 2015 Location: Cumbria Posts: 20 ![]() ![]() ![]() |
I will dubble check everything and maby try a fresh ecu
Split intercooler or hoses, or oil in red ecu plug. Ray
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Could be a faulty high low switch and the ecu is switching between throttle maps 2002 90 Td5 Station Wagon
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
If switch goes faulty which way does it default to? High or low? 1999 Defender TD5 110
If have thought high to make it reasonably driveable. The throttle map in low range is incredibly soft
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1179 ![]() ![]() ![]() |
The cause of my judder has been diagnosed......
I'm not heavy enough on the gas when pulling away an a broken engine mount:bush is causing vibration ![]() Will get that sorted next week hopefully. Oh , an a worn a frame bushing clunking ![]() G My confidence has been writing cheques that my abilities can't cash for years. |
Hi all I unplugged the hi/ low switch and have been trying it over a couple of weeks and seems to have stoped kangarooing I will have to give a new switch a try and see how that goes fingers crossed will update when the I have fitted the new switch. Thanks all for the advice
