![]() | Home > Puma (Tdci) > Extended warranty. Good news bad news |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2672 ![]() ![]() |
I've just had the screen frame replaced due to corrosion. I mentioned thsat the blocks were just as bad, and they were replaced as well. No questions 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Go back to them about the window blocks, as they're pretty clearly not trim as they not only hold the windscreen frame in, but attach the front edge of the roof to the car.
![]() If the dealer still refuses, go above their head and contact JLR customer services directly. |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 591 ![]() ![]() |
Will do.
I've gone to the dealer I bought the car from but there is one closer. Before I kick off proper I'll try them first I'll also let them put the gearbox back together too before throwing peanuts at the service monkey. |
Leeroy Member Since: 01 Aug 2015 Location: East Yorkshire Posts: 261 ![]() ![]() ![]() |
Mine has been in and had the dreaded rattle sorted once but was back today for the very same thing is booked in on the 14th for them to take a proper look and then I will find out if this can be done under the extended warranty.
I had my window blocks replaced and some corrosion done around the window, but I did ask today about perished rear window rubbers and tha was a no. Mine has done 45k and still really enjoy it I think I will extend the warranty again but guess should wait for the outcome of the rattling and if it is covered Cheers Lee |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
I've found the LR warranty a very hit and miss affair... I had some issues which should have been covered, LR customer relations said 'yeah that's covered', However as I was out of the country at the time, I couldn't get the truck to the dealer... Then when I did, I got the usual... Your out of the warranty period...
I've had a genuine LR warranty for last year and have re-new'd it for this year, It's expensive, But saved me having to fork out for a clutch and I think this years will probably go on sorting a minor niggle with the wipers... It's always swings and roundabouts with these things... Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
I think the problem is the dealers being hit and miss rather than the warranty its self. I think a lot of the time the dealer just takes a guess at whether something might be covered rather than actually checking with the warranty provider.
It pays to go above the dealers head if you're not happy with the initial answer you get from the dealer. I get the impression JLR aren't as good at spot checking their franchisees as some other manufacturers |
Dealer called whilst I was in work and said all work was complete and could I arrange a time to collect this afternoon. It's 2:30 I said and I don't finish work until 5:30 and you are over an hour away. Erm... was the response
Did he expect me to drop everything when he clicked his fingers?? Collecting tomorrow and driving straight to the tyre fitting place to get four new Goodyear MTR fitted that arrived from Germany this week and then to mot it |
The rattle has gone
But The clutch has a bite that means I have to push hard to the floor. I can't be bothered to do the 100 mile round trip to get the push rod adjusted so looks like I'll be doing it. MOT was completed by my local man and I've got the truck back for the bank holiday weekend |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Check that they've actually done the push rod locknuts up tight. My (ex...) dealership managed to miss that and I found out in the rush hour in Lyon. Towing a caravan... 700 miles from home. With a clutch that would only release if I pressed the pedal into the bulkhead with all my strength.
I thought the new clutch had failed but decided to do a bit of investigation before calling for recovery. Both locknuts spinning freely on the pushrod ![]() ![]() Green Goddess - 1998 Defender 110 300tdi |
Adjusted this on Monday and have driven a round trip of about 400 miles since. The gear change is loads better. It is a very positive early disengagement of the clutch now making for clean changes.
I have it on the end of the rod now with no more adjustment available but it works. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 ![]() ![]() ![]() |
E.W. is not available on Defender in Aus, so after 3 yrs ya're "on your own"!
Pickles. |
I didnt buy the car until it was just three years old and was provided with two years extended warranty. It took me ages to find the right car about twelve months ago and I wouldn't have bought it without the warranty.
