Home > Technical > Can you run a fridge from 12v in the rear?
Dieselhead
Quick question guys
I was given a camping fridge which runs on Gas, 240v & 12v DC
We are going camping for a few days & thought I would try it out Cool
Now can I run the beast from the 12v wiring I have in the rear of my 110? I am getting a socket to fit in tomorrow.
Its says on the sicker on the rear of it 12v DC 75W. How long can you run a fridge on a battery until its flat. I can borrow a leisure battery also. Never used a camping fridge before so I dont want to get caught out with flat battery on my landy Embarassed
Thanks for the help Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #625741 21st May 2017 10:00am
Caterham
numerous factors here;
is the 75W mentioned max load or typical running load? that equates to circa 6 amps so best check on the fuse size for the rear outlet you're fitting first.
what condition is the battery in and again what will the actual electrical load of the fridge be (ie it should be less if the ambient air temperature is low and the fridge is set to a relatively high temp.
all I can say is I have an engel fridge and the battery warning alarm often went off on start up due to low voltage but still decided to take a gamble and left the fridge plugged in / on while on the ferry for 30 ish hours - started now problem.
good luck.
Post #625743 21st May 2017 10:19am
BobT
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
You can buy an inline cut out that turns the fridge off when the battery voltage drops beyond a certain level. The good thing is your car will start, the bad is your beer may get warm.
Post #625744 21st May 2017 10:19am
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
As the others have said it's a 'rabbit hole' trying to work out how long you can get from running a fridge.
I would definitely use the leisure battery if you have access, but you would probably want to source a split charge to keep it topped up.
Leisure batteries have capacity ratings based on Amp / Hour, a low cost deep cycle battery with a 100 amp/hr capacity will not give you 100 hours at 1 amp. The reality is that you will probably get about 80% of its capacity before it needs recharging.
The 3 way fridges tend to be pretty inefficient using 12v so I would calculate 6amp /hr.
The balance you will need to do is get it cold on mains power or gas and then try not to open it too often and ensure it isn't in a really hot ambient temperature in the car so it doesn't need to use power so often.
Compressor fridges seem to be the most efficient and I think the newer ones are getting more efficient, my fridge / freezer draws about 1.8 amp per hour in UK summer temps.
As a rule of thumb I use the amp/hr rating and then 20% of the leisure battery capacity rating as a guide to the number of hours I can get between charges.
Post #625763 21st May 2017 12:12pm
Panda
England 2015 Defender 110 Puma 2.2 XS CSW Fuji White
Hi
Have used these fridges in the past. I would recommend running on car battery (engine running) until to you arrive at your campsite and switch to gas, they work better on gas.
Cheers Wink Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Muddly XS 90 TDCI-Sold
Pearl Disco 2-Sold
Larry Disco 1-didn't want too but sold
Post #625812 21st May 2017 5:27pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Thumbs Up for running on gas but make sure it is not in a confined area as you do not want carbon monoxide poisoning. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #625824 21st May 2017 6:08pm
I used one of these for a Morocco trip many years ago and I, too, ran on 12v whilst moving and gas when stopped. The current draw is pretty high and you'd end up with a flat battery within a day if used when not running. Darren
Post #625831 21st May 2017 6:40pm
Dieselhead
Thanks for all the info
Will have to do some tests with it when I have more time. Its only 3 nights so will leave it for now & have never worried in the past
I have only had it a couple of years & never worried about it until now Sad Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #625902 21st May 2017 9:18pm
