![]() | Home > Tdi > Strange compression tests results, need advice. |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 363 ![]() ![]() ![]() |
Hi there.
I won't claim to be an expert but I think the runway was because of the blowby or possibly from a cylinder with broken ring pumping oil into the turbo via breather. (Intercooler full of oil) But I would first try the following. I would install a bottle,as drain, onto the breather and disconnect the breather system from the air intake. Otherwise I would check out the turbo. Also remove the intercooler and rinse out with petrol. But be sure that it is dry before starting. Compression should be around 348Lbf/in□ or 24bar. (For 300tdi) So 2 are a bit high but if it runs ok I'd leave it. |
