Home > Off Topic > Rig Pictures |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
For your general Interest
Dundee Click image to enlarge Offshore over platform Click image to enlarge Click image to enlarge Original Member Pie n Pea Club. 110 HCPU Tipper |
6th Mar 2011 10:38am |
Some platforms have a drilling package built in and do their own drilling and workover, just hiring a firm that provides labour etc. But alot are too small or the drilling package has been removed. With the newer generation Jack up Drilling rigs they can skid out their drilling derrick up to 90' aft of the transom, also transversing side to side. They can then drill either new wells in empty slots or re-utilise old slots by sidetracking the existing well. The rig can also change out the existing production (completion) equipment in existing wells that have failed tubing or failed pumps. Alot of smaller Oil firms are buying up the older assets and with new 4D seismic are finding small pockets of oil and drilling new sidetracks into the new targets. Mostly now we run electric pumps (ESP's) into the wells once complete as the formation pressure has fallen below that needed for the well to flow naturally. The rig actually floats and is towed out to the site, we then run anchors and with the aid of the tugs position it alongside (often as close as 1-2m) then pin in position with the legs. Jack the hull out of the water, test the sea bed by filling up with water, then jack up to working height.
New platforms generally have the wells pre-drilled over a template, then put the platform in place, then the rig comes and ties them back to surface and runs completion equipment. Original Member Pie n Pea Club. 110 HCPU Tipper |
6th Mar 2011 11:08am |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Very interesting Willy
I think it would be a bit cold for me though out there NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
6th Mar 2011 11:15am |
When I say float
6th Mar 2011 11:30am |
Close Shave
6th Mar 2011 11:37am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Easier than getting the mop out to clean the deck 130's have feeling's as well you know |
6th Mar 2011 12:53pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
I'll load some pics when I got home of fixed drilling platforms Russell
2011MY 110 XS USW Black |
6th Mar 2011 1:10pm |
Just to follow on from Willie's her are some fixed platfroms with drilling rigs onboard.
This is Brent Charlie and Brent Delta in the background, there's team in the office above me working on the Delta Decommissioning. Photo taked from Brent Bravo Click image to enlarge These are a couple for Norwigen rigs pos Troll A/B. Photo also taken from Brent Brave which is only a few miles from Norwigen waters Click image to enlarge This is the Tern Alpha drilling derrick undergoing a referbishment last year. I was on the fingerboard. Click image to enlarge One of 4 CAT D-Mag engines that are used to provide electrical power to the Brent Alpha drilling package. Click image to enlarge In order to get to the rigs in the photos you have to board a fixed wing from Aberdeen to an old second world war airbase in the Shetlands calles Scatsta and then they are between 45minute to 90minutes chopper ride dependant on the choppers routing. In total it takes between 3-4 hours to reach them in good weather from the time you check in. And when you get a checkin time say 05:30 am it means you turn up to checkin at 05:30 am none of this be there an hour before crap. Russell 2011MY 110 XS USW Black |
6th Mar 2011 3:07pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Hope you had your lifesaver on Its nice to see what others do to earn a shilling as well. |
6th Mar 2011 6:19pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
Click image to enlarge Is this the power plant for the new defender 2012 |
6th Mar 2011 6:26pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
out of interest do the generators run off fuel shipped out to the rig or do they use the waste gas you see being burnt off? BM52
6th Mar 2011 6:31pm |
s18mcn Member Since: 11 Feb 2011 Location: cambs Posts: 51 |
kingofthesparks Out of intrest you dont know someone called BOB BROWNING do you?
6th Mar 2011 7:18pm |
They are diesel driven which is shipped out.
Mounted on to the other end of each engine is a 1 meter square alternator Russell 2011MY 110 XS USW Black |
6th Mar 2011 7:26pm |
Thats a baby, I'll get some pictures of a proper one tomorrow , Alot of the early diesels were dual fuel and could run on gas or heavy oil. Most of the platforms run turbines that mostly run produced gas occaisonally switching to diesel.
The rig we have on hire currently burns around 5000 gals diesel per day dependant on how much equipment we are using. Some Stats, the block is currently reaved with 10 lines on 1 7/8" line and can pull 1,600,000lbs with three 1000hp shunt motors, the top drive is 1600 hp and can turn pipe up to 120 to 200rpm and 60,000lbs torque continuous, The mud pumps are 4 x 2200 HP and can pump at +/- 500 gal /min each at up to 7400psi. We can rack back 30,000 ft of Drill pipe weighing +/- 600,000 lbs. It's just a big toy Original Member Pie n Pea Club. 110 HCPU Tipper |
6th Mar 2011 8:01pm |
