Home > Maintenance & Modifications > Air Filter sucked
Eduardo
Air Filter sucked
Hi there!
After some weird behavior during cold days I sent the Defender to the workshop to change the VCV and check the car.
After some days my Indi call saying that he found the culprit....
Due the suction the filter were destroyed and some pieces of paper were attached to the MAF sensor given a bad signal Shocked .
The filter was changed arounf 6.000 - 7.000 km ago.
He suggested me two options: a) change the filter more seldom or b) move to another kind of washable filter that have a more stiff construction and can recieve more load than the OEM ones.
Any thoughts?.
Cheers! Eduardo
Post #624500 16th May 2017 1:58am
Alien
Australia
Was it an OEM filter?
My thoughts are either a dud filter or a restriction before the filter.
Is it posible the raised air intake/snorkel got blocked at some stage? Cheers,
Kyle.
Post #624502 16th May 2017 5:23am
williamthedog
It could have got wet at some point.
Post #624508 16th May 2017 6:12am
LR90XS2011
as per previous post either wet or full of dirt/dust DEFENDER 90 TDCI XS,
Post #624511 16th May 2017 6:17am
roel
Must have been wet and dirty. Even after this (note before snorkel) my filter was still in one piece. just Whistle
 Roel
2003 90 Td5 (2009-now)
Post #624528 16th May 2017 7:42am
Eduardo
Thanks chaps for the hints!
I check almost all the line from the snorkel to the filter and doesnt look restricted. The filter itself doesnt appear to be clogged with dust or show signs to be wet (in fact was absolutely dry).
As far as I remember were not exposed to heavy rains or wading (summer time in Chile). Confused
Maybe a poor quality filter?
Cheers Eduardo
Post #624621 16th May 2017 2:50pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Could this have caused any damage further down the line, to the turbocharger for example? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #624626 16th May 2017 3:12pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
I read somewhere that the genuine LR filter can process 10X the volume of clean air required by a Puma engine.
Post #624636 16th May 2017 4:03pm
Eduardo
I will keep an eye on it.
Fortunately no damage in the system Smile Eduardo
Post #624742 16th May 2017 11:10pm
