![]() | Home > Td5 > Traction control problem |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
Hi All
I've just bought a 05 110 XS. its been fine for the last week but jumped in on wednesday and drove a couple of hundred yards and the traction control light came on. so i braked and the ABS was on as well. Do they run off the same sensor or do i have two problems . please help Jason ![]() ![]() ![]() I will post some pics over the weekend. I've changed loads on it already. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5799 ![]() ![]() |
They use the same sensors.
One wheel sensor will have a problem, and causing this. Andy |
Thanks Andy |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 286 ![]() ![]() ![]() |
Hi I have a spare webco abs traction control unit (the one under drivers seat )
If it's that? It's a shame your fo far away you could of tried it ![]() Thanks Ash |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
I think this is the same fault that discoveries get, commonly called the three amigos... (3 warning lights)
usually a re-seat of the sensor will cure it. although i've never done it myself. |
From just a few days ago.....
http://www.defender2.net/forum/topic7119.html?highlight= Another from me a while ago... http://www.defender2.net/forum/topic2394.html?highlight=abs Always worth a 'punt' on the search facility... ![]() Treat every day as if it is your last....one day you will be right!! |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
could possibly be the abs/tc relay, they have being known to bring the lights on 2004 TD5 Defender 90 xs station wagon
