Home > Puma (Tdci) > MAF Sensor problem (I think), code p0100 |
TIM S Member Since: 11 May 2017 Location: Peak District Posts: 3 |
I have had similar problems diagnosed as out of range injectors ECU and wiring faults and MAF sensor failure. No-one seems to be able to diagnose this beyond trying out replacements, which gets very expensive. Did you get anywhere?
11th May 2017 11:05am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20440 |
Pretty sure that is the nuisance one.
Clear it and forget it. You could also give you're MAP and MAF a clean, I was surprised how easy it is to do and how dirty they can be. This code is often brought on by a Snorkel in some cases I've heard, but I have one and have had zero issues. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
11th May 2017 12:41pm |
tracstiling Member Since: 15 Jan 2017 Location: uk Posts: 2 |
Hi, have fixed the problem. It was the wiring loom. It had chaffed/rubbed in a few places which caused the false MAF readings. You need to take the loom tape off and just check for signs of wearing and repair the area/s. Mine had two areas of wear. Hope this helps. Regards Steve
11th May 2017 5:48pm |
Thanks. I'll try that at the weekend.
12th May 2017 6:16am |
Can you tell me where you found the problems in the loom on your car? I'd guess this is a defect due to the design and positioning not a random wear issue.
12th May 2017 8:25am |
