Home > Puma (Tdci) > Dashboard switch |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17475 |
Heated seat switch is probably the best bet, it is a latching on/off with illumination and "on" LED.
Unfortunately I can't remember the part number but a search of the forum will reveal it. |
10th May 2017 11:52am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
Heated seat is YUF500150LNF - £8+VAT at full Land Rover retail price, don't get ripped off on eBay etc 1988 90 Td5 NAS soft top
2015 D90 XS SW |
10th May 2017 1:51pm |
Trundlebus Member Since: 15 Jul 2014 Location: Herts Posts: 99 |
Thanks guys, just ordered one from dealer, be in tomorrow. Now just need to discover how to get at the switches. I bet its on here somewhere, let the search begin!
10th May 2017 2:49pm |
If you want a plug I have them (can post today 1st class if ordered before 4.30pm): http://www.disco3.co.uk/shop/5-way-defende...3-p71.html 1988 90 Td5 NAS soft top
2015 D90 XS SW |
10th May 2017 2:50pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1645 |
It's quite straightforward... Unscrew the 2 'hex' nuts holding the centre fascia panel on. Then use a plastic 'trim removal tool' (available at many places) to gently lever off the plastic trim. Once you get one corner off, there rest follows easily. ll the switches are then accessible... and they are all 'handed' with the switch plugs, i.e.: they will only fit each specific switch so don't be too daunted. I did mine, and labelled them all with masking tape!! Good luck! Enjoy! YOLO... You Only Live Once... |
10th May 2017 2:59pm |
HI Martin just ordered, missed the 4:30 deadline though! many thanks for the post and letting me know I needed it. otherwise I would have been searching around to get the plug regards |
10th May 2017 3:51pm |
Thanks, it should still make the post today 1988 90 Td5 NAS soft top
2015 D90 XS SW |
10th May 2017 3:52pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 667 |
It is very easy to make a custom switch by replacing the switch cover with the blank you will be taking out and engraving / drilling hole for the led. Sure there is a write up somewhere.
10th May 2017 5:13pm |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 |
I've customized a few switches, rather simple if you have or know someone with a laser/co2 engraver...
Take a peek here: http://www.defender2.net/forum/topic53098.html & http://www.defender2.net/forum/topic42402.html Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
11th May 2017 7:16am |
just a quick thanks to all for the help and to Martin for the connector, switch now fitted and working, my problem solved
Al |
26th May 2017 6:08pm |
