Home > Technical > P38 Defender rear diff
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Need to fit a rear diff guard on my 12plate Puma, two bolt holes on the side of the diff. Thought they were standard M12 but turns out they're not. Any one know what thread/size they are?[/list]
Post #622985 9th May 2017 8:50pm
I think you'll find that they are 3/8" BSF.
See http://www.defender2.net/forum/topic52799.html
Edit - Cancel that ! It's a P38 diff of course because it's a 110. The holes are for the harmonic damper used on the P38 axle and should be a standard M12x1.75mm pitch thread. It may be that the holes need cleaning out, and it is just possible I suppose that they're not tapped.
Post #623019 9th May 2017 10:26pm
Timcat
Many thanks for the reply, definitely not M12 tried standard & fine, had two imperial bolts which were left over from the Warn winch re-build & they fitted.. god knows what they were!
Post #623197 10th May 2017 6:54pm
That's wierd because M12 is the only size in the parts book for any P38 harmonic damper bracket!
At least you're sorted.
Post #623198 10th May 2017 7:06pm
Timcat
Yes, another thing ticked off the list. Thanks again..
Post #623273 10th May 2017 10:36pm
