Home > Maintenance & Modifications > 3 LSDs
Page 2 of 2 <12
Cupboard
Well an LSD could potentially lock up a bit, depending on the type of LSD.
However, the common (and better) thing to fit to a Defender is an ATB diff - automatic torque biasing. They have a lot of similarities but are actually very different. You can get LSDs for the axles, I don't think you can for the centre. You definitely can get an ATB diff for the centre and there is a huge thread on the benefits of them.
Post #622772 8th May 2017 8:27pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
The same topic also discussed here - with some Aussie input:
https://www.aulro.com/afvb/90-110-130-defe...locks.html
Post #622799 9th May 2017 5:05am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
3x ATB (2x Ashcroft and 1x Quaife in LT230) in Def 110 with not correctly working brakes - I spent quite a bit of time to found garage with brake tester good enough for this combination. And with proper chains to hold the car for case of a problem. Car is not my, problem was in bad new brake calliper. Offroad it is very nice to drive, TC only signalizes that there is some slip, but the car moves like a tank. TC is eliminating the need for at least a bit of torque. Only drawback is the price. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #622808 9th May 2017 7:38am
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
Well Devon 4x4 have priced fitting an Ashcroft referbished lt230 with atb and sleeved casing. I'm happy with the price. I'd rather pay them to do it and just go to work. Rather than spending my weekend with bleeding knuckles and a a transfer box falling on me. Only 5 hours labour.
Diff's to follow, maybe for Xmas. 2009 2.4TDCi XS Utility Wagon.
Post #622945 9th May 2017 5:00pm
Chris, out of interest could you tell me how much they're charging?
PM if preferred.
Many thanks! Thumbs Up
Post #622947 9th May 2017 5:07pm
ChrisWoods
I don't think D44 would mind people knowing as I think its a good price. About £1600. Considering nearly £1200 of that is for the diff centre and rebuild then there's gear oil. Only a few hundred for fitting and you know it'll be done right. 2009 2.4TDCi XS Utility Wagon.
Post #622980 9th May 2017 7:34pm
bankz5152
Not bad but not the best price. Ashcroft direct is £1044 for the same inc VAT without labour. £1320 from Syncro for a stronger box with a 2 year warranty.
Post #623090 10th May 2017 9:44am
ChrisWoods
So how much would Ashcroft want to put the box in? Bonus for me is a that D44 is very close and they would obviously warrant all their work. 2009 2.4TDCi XS Utility Wagon.
Post #623101 10th May 2017 11:01am
bankz5152
Not sure, price seems to be missing from their website. Though they did my gearbox (higher 5th, HD bearings, clutch, oil, seals, fitting, VAT) for £1444, I cant quite remember but I think an upgraded tx box was around the £1200 fitted
Their work is good and guaranteed (to a degree) but Luton is a horrible place, I was there from 9am till 5pm saw 2 films and had a walk through the worlds most depressing shopping centre.
May be worth giving a ring and weighing up the price difference.
Post #623109 10th May 2017 11:30am
ChrisWoods
My price was for a sleeved casing as well so I think that's another 130quid. Well they are going to do the job as soon as Ashcroft's can get the box to them. 2009 2.4TDCi XS Utility Wagon.
Post #626459 23rd May 2017 8:48pm
ChrisWoods
Being fitted 15th June. Not gonna get much work done that day. By the time I've driven there and back twice and spent a long while browsing the new shop. Can't wait for my drivetrain to not slap and bang all the time. 2009 2.4TDCi XS Utility Wagon.
Post #628004 31st May 2017 4:29pm
Boost
United Kingdom 1986 Defender 90 200 Tdi SW Arles Blue
defendermatt on here's using front, rear and centre ATB's I believe, once the project gets on the road that is Whistle Thumbs Up
Post #630344 10th Jun 2017 11:30am
mikeh501
my project has 3 ashcroft ATBs also. not turned a wheel yet though lol. the centre diff wasnt that expensive and given I was having a box recon'd it didnt seem a bad idea. hopefully a bit stronger and less slop.
Post #630376 10th Jun 2017 2:55pm
Page 2 of 2 <12
