Home > Maintenance & Modifications > Passenger grab handle |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
fits on the standard screw holes that hold the trim in place.
But you need long-ish screws, and I have had a few occasions when the handle just rips out if you use it to pull yourself into the car. X4SP's solutions is much better, except I would use a soft handle, in case you bang you head against it while off-roading. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th May 2017 8:12am |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
Very neat solution there SKIP - thanks for sharing.
9th May 2017 6:51pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 886 |
Driver and passenger grab handles are on the list for me too. (It''s a long list.....)
I'd have thought one of the suppliers would have picked up on this and come up with an off the sheff option by now. It's something that could be easily engineered in my view given a bit of time. Mud etc.. should be on this as it's a common conmplaint by passengers and is available in any other car on the market today. Does anyone have a part number for the standard handles that fit on the A pillar and the screw size/length needed. I'll get those added as an alternative to see if this solves the problem for now. The list in never ending... I did saw these mentioned on another tread... Interesting but not exactly beautiful... http://acc16.com/supportgpspassag/index.html |
11th Apr 2019 1:55pm |
