![]() | Home > Technical > Front driveshaft flange refitting issues. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
It may help to get the circlip on before bolting up the drive flange. Then you have play to move the flange to wiggle it about to expose enough for the circlip
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
You've put a bolt in the end and tugged the CV out as far as it goes? (The copper thrust bearing should be the limiting factor)
Steering is straight? Solved the bowel problem, working on the consonants... |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 294 ![]() ![]() |
Hi, thanks both for replies.
grafty99 - will give this way a go as soon as I can get back to it agentmulder- tried with the bolt as previously done with the opposite side, steering straight too. Will spend a bit more time it over the nex day or so and see if I can see any other reasons. 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 301 ![]() ![]() ![]() |
Had the same issue over the weekend.
Drive flange bolt in the drive shaft with a bit of wiggling and rocking the hub forwards and backwards sorted it. Gearbox in neutral with hand brake off to get rid of any pre load. |
Hadn't thought of the handbrake being on - which it currently is. Will giver another go tomorrow. Thanks for the info
![]() 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
Now sorted, had the handbrake on which wouldn't have help. Also got a new flanges the orginal one was worn, so the combination of both plus pulling on the bolt gave me enough room to get the circlip on. Now onto the next job. 1999 300TDI 110 CSW BMW 3.0
