Home > Td5 > Odd speedo response |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Mine does this VERY occasionally (maybe twice in the last 3 years) It hasn't happened for a while though. I can only think that it is either a very intermittent earth fault or just where the transducer is stopped in a certain position and the electrical interference on start-up generates a pulse that makes the speedo jump. Mine went to about 70mph and stayed there for a couple of seconds 2002 90 Td5 Station Wagon
6th May 2017 8:53pm |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 |
Thanks for the reply Grafty99.
Presume then its just a blip in the electronics. Edward |
6th May 2017 9:00pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
I've noticed mines doing this once in the last two years, nothing has come of it so I suppose it was just an electronics glitch.
6th May 2017 10:10pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
Usually happens when starting on a low battery.
Also sometimes you will notice the fuel gauge go to empty. Signifies your battery or grounding has issues. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
10th May 2017 4:09pm |
