Home > Maintenance & Modifications > Greasing points
Chopperone
Greasing points
I am trying to track down a schematic diagram of the greasing points on a 2007 Puma.
Failing that am I right in believing that there are just 6 points........
4 x UJs & 1 on each prop shaft?
TIA
Guy May your life be like toilet paper ; long & useful.
Post #621208 3rd May 2017 6:10am
Correct, but even those may not all have nipples fitted.
Post #621229 3rd May 2017 8:12am
zsd-puma
On my 2010 car i've got nipples on the UJ's but not of the propshafts (not even a place for them)
Post #621292 3rd May 2017 11:56am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Same on my MY 2015. I was told you could peel back the rubber sleeve and put a little grease in there. ?
However, I found a service bulletin:
Quote:
SSM40851
Defender Front and Rear Propshaft Grease Points
Models : LD - Defender
Title: Defender Front and Rear Propshaft Grease Points
Last Modified: 30-MAR-2009 08:27
Category: Noise/ Vibration
Symptom: 703000 Vibration Concerns
Content Issue: Loose or missing front / rear propshaft grease nipples for Defender 07 MYonward vehicles.
Action: If any propshafts are identified where the grease nipples are missing, then the propshaft should be replaced. Any cases where the grease nipples are in place but loose should be torqued to 8Nm + 45degrees.
Not sure though which VINs this applies to. My Defender has no open service issues.
Post #621594 4th May 2017 11:21am
Cupboard
My 2011 propshafts have no noticeable nipples, and I've just been looking.
Post #621678 4th May 2017 5:10pm
