Home > Technical > After an engine rebuild
Jonathan111
Hi all, just had the 300tdi (110) back from a major overhaul (lock up on overheating, thanks to the many who advised through that little adventure) and all seems to be well, but garage has insisted on T&Cs on warranty being that I have oil and filter changed after 500 miles and tappets adjusted ditto. Just wondering why this is, and if there is any other advice about running the engine in, or driving differently, speeds, loads etc in the weeks ahead, any thoughts gratefully received, cheers, Jonathan
Post #620774 1st May 2017 3:26pm
Balvaig
You forget about running in with modern engines.
Main points:
Keep revs low when engine cold. No sudden stress or acceleration ( I Know- its a defender)
Don't over rev when warm, keep to best gear without stress.
Don't drive short distances regularly.
As running in period progresses you can increase revs slightly, and a medium speed long run would work wonders.
Fastish motorway run towards end of running in period best.
All bits will be removed with filter change and oil change at 500 miles.
Thereafter steady driving for next 1000 miles will pay dividends in the long run.
Check with garage, but a 3000 miles oil/filter change might be advisable.
Post #620782 1st May 2017 3:50pm
Jonathan111
HI there, thanks, very useful, much obliged to you - what period should the running in cover, just the 500 miles?
Post #620784 1st May 2017 3:53pm
grafty99
Running in happens for a long time but it is generally considered that after the first 1000 miles then the engines full potential can be used.
Maximum economy and power is generally around the 30 - 50,000 mile mark. Although this is only a rule of thumb and differs between engines Thumbs Up
I would say the garage is a good one for demanding a 500 mile oil change Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #620789 1st May 2017 4:39pm
Jonathan111
much obliged, thanks very much, all very useful, cheers, Jonathan
Post #620804 1st May 2017 5:09pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Varying loads. A nice country road, not a motorway drive
Keep revs low, but full throttle can (and should) be used
Thumbs Up
Post #620830 1st May 2017 6:30pm
Disco_Mikey
Post #620835 1st May 2017 6:39pm
Jonathan111
cheers, much obliged, will take this advice, all best, J
Post #620880 1st May 2017 8:11pm
