![]() | Home > In Car Electronics > Do you fuse jump lead connector? |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 ![]() ![]() ![]() |
The plan is to fit an Anderson connector (170A) onto the base of the passenger's seat. Now would you fit a fuse to this connector even though it is a short run of wire? If I was to fit a fuse what kind of rating would I be looking at?
Would it also be wise to fit an isolator or is that just extra faff for no advantage? ![]() |
trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 102 ![]() ![]() ![]() |
Most definitely "yes" (big fire risk without), Fuse size depends on what you are going to use the supply for.
Starting another diesel engined vehicle from cold, could pull upwards of 150-200 amps momentarily, so you are looking at a very large fuse. (not a good idea).
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
Some info here might help:
http://www.defender2.net/forum/topic19462....+connector http://www.defender2.net/forum/topic35114....tor+bonnet I've got a 300amp fuse on mine fitted very close to the battery, and (2.5 metre if I remember correctly?) leads that run out of the battery box then underneath and up and into the engine bay with the Anderson connector fitted near the heater box. I preferred the connector to be under the bonnet for easy access from either side of the vehicle, rather than on the seat box. All made up and supplied by Tim at the Mobile centre and fitted by me. Couple of photos: ![]() Click image to enlarge ![]() Click image to enlarge |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
A mega fuse will do the job if you need one. Whether you need one and whether you need an isolator will depend on how you install it, how you run the cables and how much trust you have in the people using it. To an extent it also depends on the quality and size of the cable you use.
There's always a dilemma when fitting heavy cables to a battery. You can't have the whole thing fused, that's impossible. If you install a mega fuse where will you mount it ? The cable between the mega fuse and the battery is still unfused and if you can't run a cable between an Anderson on the side of the seat and the battery terminal with suitable protection (conduit, rubber grommets etc...) then how are you going to make the run to the fuse safe ? The same applies to a key switch isolator, you always end up running additional cable in order to isolate the cable that was already there. Solenoid isolators can be installed right next to the battery terminal so are better in that regard. If you consider your cable run to be safe then you are never doing anything more with the Anderson than you would with a traditional jump start cable which you would never consider having a fuse inline with. You do, hopefully, take extra care though when handling and one of the disadvantages of the Anderson for this purpose is the inability to connect one cable at a time. All that said, if you don't trust the people likely to connect something to the Anderson then adding a fuse might be a good option ![]() |
That was my thinking. The issue with connecting to the Anderson is solved a little as I will keep croc clips at one end of the jump leads. Though I may just fit an isolator just in case some numpty touches the leads together or they are the wrong way around and I can't pull the Anderson quick enough, thinking emergency stop button. http://www.ebay.co.uk/itm/162064834595 I have a fuse for the run I have from the spare battery to under the bonnet but that is because it is 2.5m of wire and the risk of it shorting is higher than a <0.5m length of wire. 25mm2 to reduce drop and it may end up as an access point if I need to power a compressor etc. ![]() |
