Home > Maintenance & Modifications > Fuel/money saving remap. |
ChrisWoods Member Since: 29 Dec 2016 Location: Spreyton Posts: 164 |
That's interesting. I usually get 26 - 27 mpg using the truck for work. Some towing. All lane driving. I'll work out mpg once I've got the new map and report back. 2009 2.4TDCi XS Utility Wagon. |
1st May 2017 3:36pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7906 |
I've never dared calculating mpg before or after but after is SO much better it was definitely worth it! James
1st May 2017 4:44pm |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
1st May 2017 4:47pm |
Well now the map is installed I will have a definitive answer. Previously my average was 27mpg.
Update in a month. 2009 2.4TDCi XS Utility Wagon. |
5th May 2017 7:10pm |
Well first tank of fuel. 23mpg but that's with about 100miles of towing 2.5tonne, a few evenings out in the fields shooting and a short 100mph spat to make sure the speed limiter had been removed. I'm hopeful for my 2nd tank as my driving is back to normal after testing the map.
It goes like a stabbed rat. 2009 2.4TDCi XS Utility Wagon. |
15th May 2017 9:22pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2642 |
Install cruise control....
Normally i get 250 miles max / tank my last tank i got over 280... main difference is i installed cruise recently and been using it a lot. Thats a alive PP4, roof rack, Shell v power.. |
15th May 2017 9:50pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
I got a BAS remap on my Puma in 2011 (1 year into ownership). It paid itself in fuel savings within the first 2 years --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
16th May 2017 7:39am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3373 |
Over 15k miles I've averaged 23.5 mpg in the 110 since the remap.
The best tank it's done in that time is 24.5 mpg and the worst is 22. Most of that is on the motorway however which is what keeps the mpg down, |
16th May 2017 9:15am |
Which map did you go for in the end?
Good call. With a remap it's all too easy and comfortable to go too fast, which drinks the fuel. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
16th May 2017 11:46am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8051 |
my own experience with td5 was first 40k miles around 26mpg mixed, next 60k miles 29mpg with remap. but then that could of been the running in toooo!
had a VW that did std 36mpg, after remap did 45mpg on same 1000mile weekly commute so comparable over 50k miles. muy experience with Puma is better mpg once mapped unless you use the extra grunt, like towing when i typically saw lower mpg with remap than towing without remap. Something else to ponder, as elduded to. transfer box is 1.2std on Puma, fit a 1.4 if you want better pick up (but will give more revs at cruising. I have a 2007 std tune with a 1.4 t box on 33" tyres. it does tows better than my 2.4, 1.2 remapped on 31" tyres. and uses less fuel towing or not. GPS miles on both. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
16th May 2017 12:06pm |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
Defender TD5
Dynachip Stage 1 - MPG went from 23ish to 25ish TD5inside Stage 2 - MPG went from 25ish to 29ish on a good week These are obviously after the initial week or so when you're putting your foot down a bit... Discovery 3 BAS 'stage 1' remap - MPG actually went down from 26ish to 23ish MPG That backfired but huge difference in responsiveness (wouldn't change it). I use an app to log mileage so can verify all on both vehicles (only TD5 below). Click image to enlarge TD5 Defender 90 Discovery 3 HSE |
16th May 2017 1:44pm |
Which map did you go for in the end? I'm not sure, thought there was only one BAS map for the 2.4. Think its the 165bhp and 440Nm. The engine is sweet but when using the extra torque it highlights my drivetrains issues. Gotta get them sorted this summer. 2009 2.4TDCi XS Utility Wagon. |
17th May 2017 5:54pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
Last fill up on my 300tdi 110 HT, was at 340 miles, and got 32.3mpg on fuelly.not back at 170 k and 19 years old
20th May 2017 6:08am |
As my right foot gets lighter my average mpg is going up. Back to 26mpg now and that's with me still using most of the grunt and occasionally driving like I stole it on a quite A road. BAS Intercooler next so see what difference that makes. 2009 2.4TDCi XS Utility Wagon.
7th Sep 2017 9:33pm |
