Home > Td5 > Black smoke TD5 |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5172 |
Black smoke sounds to me like Fuel, have you had the injectors cleaned or serviced? I would try running a treatment through and change where you fill up 1st. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
29th Apr 2017 11:22pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2168 |
Black smoke is usually an imbalance or fuel and air. Have you got any diganostics to get live readings?
Is your inlet manifold clean? And are you boosting 14psi? |
30th Apr 2017 5:02am |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 |
I would be checking turbo/intercooler hoses for blockage. These can delaminate inside & impede the air flow. The intercooler itself could also be partially blocked & may need cleaning, particularly after the distance your vehicle has travelled.
Is engine performance OK apart from the smoke? Most of what I have described would result in reduced or variable power output. Cheers, Lionel |
1st May 2017 11:57pm |
Joao Pinto Member Since: 29 Apr 2017 Location: Lisboa Posts: 2 |
Hello, good morning, Lionel.
The material I have described is totally new. They have not done so far 10,000 km As for the engine, taking the smoke is fine Regards Joćo Pinto |
2nd May 2017 6:05am |
