Home > Technical > 2.4 Puma - Original ECU settings - how?!
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
Question is... are they all running off the same configuration?
If I remapped my ECU and wanted to return to the original setup, how would I go about doing this? I have little knowledge on such things.
Are the ECU settings specific to the actual model and year etc? Or will any equivalent size (2.4) of engine work?
For example... would a 2010 plate 2.4 Puma ECU have the same setup as a 2008 one for example if the car was a different spec - electric windows for example...
thanks
Stuart
Post #619926 27th Apr 2017 2:19pm
Your ECU is configured to your unique engine, and indeed adapts itself to the engine's particular characteristics, especially when new. Although it is likely that the engine will run (at least once the alarm/immobiliser issues have been sorted out) with a different ECU, it will not run well.
If fitting a new ECU, at the very least you will need to sort out the alarm/immobiliser, and then code the injector initial calibration settings into the ECU, and then carry out injector and fuel pump "learn" cycles.
Post #619940 27th Apr 2017 3:02pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
If you get something like the BAS remote remap tool you can have the tuned map but then simply reload the standard map whenever you like.
Post #619964 27th Apr 2017 4:41pm
stuart123
Thanks for the replies, think I will go down the Alive route...
Post #621336 3rd May 2017 2:04pm
I have the Alive stage 1 with ATRIC device on my 2.4 Puma. Very pleased indeed. Thumbs Up $W33T $0U7H3RN $UG4R
Post #621367 3rd May 2017 4:37pm
Peterwat
Australia 2010 Defender 90 Puma 2.4 HT Fuji White
Alive remap
G'day Steve,
I'm very interested in chipping my recently purchased 2.4 puma. I take it you are happy with the Alive option and is there any look out for me. Thanks mate
Peter
Post #632012 17th Jun 2017 10:12pm
