Home > In Car Electronics > Rear indicator wiring
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
Hi all, my right rear indicator had a lose connection which was rusty so I ordered a bearmach extention and cut off the connector.
I have attached scotchloks black to black and green white to green but now the indicator won't work.
What have I done wrong?
Thanks
Tim
 2001 90 TD5 CSW Alveston Red Manual
Post #619699 26th Apr 2017 7:04pm
If that'd be me, I'd be soldering that joint and using adhesive heatshrink and get rid of those awful scotchlock things.
You need to test earth continuity with a Multimeter and for voltage at the pins.
Have you checked the fuse hasn't blown? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #619708 26th Apr 2017 7:30pm
Check the obvious stuff such as fuse and bulb and, as Steve says, test for continuity to earth and 12v.
The Scotchlocks really are a poor solution but unless you've made a real hash of fitting them, they shouldn't be the cause of your woes whilst brand new. Darren
Post #619712 26th Apr 2017 7:49pm
timtom1
Where does the right indicator loom connect to can you get a fresh piece ? 2001 90 TD5 CSW Alveston Red Manual
Post #619759 26th Apr 2017 9:41pm
It'll be continuous right up to the front of the vehicle via the loom that passes up through he chassis rail. Practical options are to solder and heat shrink the joints as Steve says or, if there's enough slack, fit a new plug to the cables at the point where you've currently joined them. Darren
Post #619787 26th Apr 2017 10:40pm
Fatbaron
I'll state the obvious... Have you tried turning the bulb round? I made that mistake myself!
Post #620308 29th Apr 2017 7:03am
timtom1
thanks all, solved it was the scotchloks not making a proper connection. 2001 90 TD5 CSW Alveston Red Manual
Post #620310 29th Apr 2017 7:43am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Scotch lock's should be banned. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #620329 29th Apr 2017 10:29am
Glad you found the issue, now time to ditch them. Solder and heatshrink or ho back to an Econoceal as suffered if there is any slack left. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #620334 29th Apr 2017 11:09am
zsd-puma
Used Scotchlocks. Laughing
These;
http://www.autosparks.co.uk/electrical-com...-00mm.html
Are a good alternative to soldering and heat shrink, crimp them like a normal butt connector then heat them up and the glue lined plastic melts to form a strong waterproof seal.
If you have any more scotch locks, just bin them they're useless things! Even if they work initially, they'll cause no end of grief after a few months at best
Post #620377 29th Apr 2017 3:30pm
