![]() | Home > Puma (Tdci) > Engine help from the Highlands of Papua New Guinea |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Can you give us more info on the EGR bypass? Was it done via a remap and/or physically? Solved the bowel problem, working on the consonants...
Cobra_Phil Member Since: 24 Apr 2017 Location: Papua New Guinea Posts: 7 ![]() |
My LR does not currently have the bypass, it is stock. I was just stating that I thought I've read that the EGR bypass could resolve the overheating issue. Sorry, didn't word it very well.
Beery Member Since: 16 Nov 2014 Location: NSW Posts: 36 ![]() ![]() ![]() |
The cooling system will now be coated with oil on all surfaces unless it has been properly cleaned.
This could cause the overheating you are experiencing. Does the engine provide normal power/operation before it overheats? |
I was told it was flushed several times and from my checks, the coolant looked clean.
It is definitely under-powered. That along with the lack of boost and pressurized coolant system points to additional problems. |
R1200GS Member Since: 12 Jul 2015 Location: Hampshire Posts: 265 ![]() ![]() ![]() |
Oil in coolant normally points to cylinder head gasket failure...?
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Sounds like a core issue that's caused the overheat but now cyl head warped or gasket gone. Pressurising coolant is defo bigger issue now. Sounds remote with no tools. Can anyone else help you? 1951 80" S1 2.0
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8165 ![]() ![]() ![]() |
were their any symptoms prior to failure? or anything not right?
remapped? what load was it under at failure? how long running how heavily loaded, how many miles? frequent oil changes? water pump working? when it gets hot it will cut power and feel booged down. does it run with power until it get too hot? or no power from immediate cold start? turbo is free to spin? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 554 ![]() ![]() ![]() |
That's a 2.2 from 2012, could it be an oil pump failure if it didn't have the recall done? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
I am very remote. I do have help, but no one with more mechanical skills than me.
No symptoms prior to overheat. 2nd gear, climbing off-road incline, very heavy bog for several seconds - pedal to the floor, less than 13k miles on odometer, not sure about frequency of oil changes, I've had the vehicle less than 6 months. No problem with water pump. From startup it is low on power. Turbo spins freely, but definitely no boost. It has stock ECU. Because of where it is located, I'm sure it did not have the oil pump recall performed on it. Thanks. |
ok, cheers, is it using coolant or oil at all now or hard to tell? Cheers
I am not driving it at all now, so hard to tell.
xcentric Member Since: 17 Jan 2016 Location: Midlands Posts: 247 ![]() |
others are probably much more expert than me, but if the coolant is getting pressurised then it would suggest that you have some influx of stuff into there, hence head gasket failure and oil leak plus engine pressure causing issues.
Lack of power could be related to leak in turbo/connecting pipes, but that is not likely to result in the other symptoms you mention, unless the engine is overheating cos it's working too hard without turbo assistance. I think you need to take as many spares in terms of hoses, gaskets, water pumps, oil filters etc as your baggage will let you have, ideally on a sale or return basis, and focus on trying to identify the problem this trip and fix it next. A good phone/satphone with mobile internet might be your best bet to connect you with experts here when you're there! I'd also try to hook up with people in Australia before you go who can ship parts to you as you might need them - faster than from the USA..... |
Thanks for the input.
I am thinking of purchasing this kit off Ebay to get it started shipping towards PNG. http://www.ebay.co.uk/itm/Landrover-Defend...P#shpCntId It should provide most of the bits and pieces I might need in case it is a head gasket, oil pump, cracked piston, broken piston ring, etc. I know it might not be the right head gasket but my main goal it to get it running. I have a straight edge on the way so I can check for a warped head. Other tools I have thought of include ODBII Scanner/Reset tool, engine compression gauge, and hydrocarbon test kit (if I can get it on the plane). For anything major like warped head, split inter-cooler/hoses, turbo issue, etc., I will just have to order the parts and wait. I won't be coming back to the States for 1-2 years. I do have limited internet access (dial-up speeds) which will allow me to stay in contact with this forum and others that can help. Still looking for ideas that will help troubleshot/resolve this problem. Thanks. |
do you have the Workshop manuals?
MY2007-2011: https://1drv.ms/b/s!AnHBx4Wc2MJLhG6rtxe8woH3N2w8 MY2012-2016: https://1drv.ms/b/s!AnHBx4Wc2MJLh311C6cNIArhJ6ag How to: Defender 2.2 TDCi Service Intervall Reset 1. Ignition ON pressed both brake and accelerator pedal down for 15 seconds 2. Oil light started to flash. 3. Turned the ignition OFF and left it for around 2 mins. Oil service indicator cleared. Several "tons" of documents here: https://1drv.ms/f/s!AnHBx4Wc2MJLgcZkI7QQv8JNpcaljA (wiring diagrams, electric library, and much more) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
