Home > Maintenance & Modifications > Chassis to Gearbox earth |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
I always make up my own, a bit of heavy copper braid, or 25 - 35mm cable, and a couple of copper tube ring terminal lugs and you're done.
25th Apr 2017 5:42pm |
PRC2015, PRC5499 or PRC3625.
It's not clear which one is which. But none are anything special and you can make your own up to a higher spec for much less money. |
25th Apr 2017 6:07pm |
25th Apr 2017 6:24pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
Thank you Clive and ZSD I thought it might be easier to do one myself.. I shall have a rummage in the garage. 1993 200Tdi Defender 90
25th Apr 2017 6:40pm |
Thanks.. I had seen that.. pricey! 1993 200Tdi Defender 90 |
25th Apr 2017 6:50pm |
pricey your not wrong there
Make your own one to army spec I.E crimp terminal lugs and then solder them and heat shrink sleeving on top |
25th Apr 2017 7:22pm |
There are a few military ones on ebay.
25th Apr 2017 8:56pm |
