![]() | Home > Tdi > bigger fuel tanks? |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1634 ![]() ![]() |
replace with a standard one and paint it well and waxoyl before fitting and then add a rear td5 tank which keeps it std parts.
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Sounds interesting, is there much fabrication in adding the td5 tank? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
depends on how you mount the new tank
its been covered loads of times in every different way possible including big custom tanks some folk move the batteries and fit one under the passenger seat instead. http://forums.lr4x4.com/topic/71138-td5-fuel-tank-in-200tdi/ there is a fairly good write up of job here |
