Home > In Car Electronics > Installing electric windows
cashpat
United Kingdom 2001 Defender 110 Td5 SW Alpine White
This might have been covered previously but I looked around and found nothing specific to my question. So, an 01 110, would it be possible to install electric front windows? If advisable then, is the equipment easy to come by for the defender or is it necessary to convert from another model? Finally, if it can be done, can it be done by the keen amateur?
Post #619065 24th Apr 2017 9:42am
bankz5152
A quick google will reveal you can buy electric window kits for a Defender.
Literally 2 seconds on google. http://www.paddockspares.com/defender-electric-window-kit.html
Yes its easy.
Post #619069 24th Apr 2017 9:54am
cashpat
Cheers for that. I had meant a look on the forums here. No matter, you've pointed me to the gear and I'll trust the set up is easily installed. Thanks for the help.
Post #619070 24th Apr 2017 9:58am
bankz5152
Yup, pretty easy to do. Its quite straight forward, effectively replace manual bits with a motor. Only thing thats a tad annoying is the door cards will have a random hole from the window winder
Post #619074 24th Apr 2017 10:11am
cashpat
As you would imagine on an 01, random holes have become part of its make-up. More annoying than that though would be trying to find 200 quid for the pleasure of not winding myself up. Might keep an eye out for something on flea-bay while the wallet is resting. If you hear of anything cheaper then do get back.
Post #619076 24th Apr 2017 10:14am
bankz5152
You can buy universal kits for about £50 but not as plug and play and not as neat
Post #619089 24th Apr 2017 11:23am
zsd-puma
Don't the kits come with a plastic bung to go in the hole?
Post #619093 24th Apr 2017 11:31am
