Home > Maintenance & Modifications > Rust!!!!!! |
Developing?! I'd say that's already developed. Idealy it's going to want cutting out and having a new bit welded in. |
22nd Apr 2017 9:19pm |
NMBRPL8 Member Since: 07 Jul 2015 Location: Australia Posts: 144 |
Dont back your trailer so far down a boat ramp,
23rd Apr 2017 2:15pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Really you needed to stop it before it got to that stage as welding the door area is a skilled job, i'd take it to a good specialist since it looks like the rust has bitten into the anchoring point for the hinge. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
23rd Apr 2017 3:41pm |
agreed, once you start cutting out the rot you'll find a much much bigger hole.
What is the other side like? Chances are it's starting to go too, but might be early enough to save it yourself. |
23rd Apr 2017 6:36pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
replace with a galv bulkhead..... if you have that level of rot there, it will likely be riddled! Check your foot wells etc.
Any repair you do will be temporary. |
23rd Apr 2017 8:08pm |
Brendlynch Member Since: 06 Nov 2016 Location: Grouville Posts: 182 |
Cheers all
Yes to be honest it was a bt of a shock when I peeled back the door seal, and has completely caught me in the hop. This has taught me to keep more of an eye out in future. The other side appears to be free of corrosion and I've had a good look around foot wells etc which are also ok (on the face of it) so just hoping that that problem is isolated to this area. Anyhow, will be taking it to a well respected body shop tomorrow to get it looked at. Will report back on the verdict. |
23rd Apr 2017 9:28pm |
I don't think its that bad 1993 200 Tdi 90 CSW
23rd Apr 2017 10:16pm |
