Home > Tdi > Engine starting problems
Page 2 of 2 <12
jst
if fault was there before its unlikely to be the filter as you say.
once you have tried the stop solenoid if that doesnt work
try a can of diesel on the floor, take supply from tank off the lift pump and using known good pipe connect fuel can to lift pump, prime it and try that. then leave it for a while see if it starts next time.
will tell you if its supply leak to lift pump or onwards or return leak. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #618505 21st Apr 2017 7:28pm
Page 2 of 2 <12
