Home > Maintenance & Modifications > Clutch Spring mod |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 |
I came across this mod tonight, is it worth doing and can you do it to a 1990, 90
19th Apr 2017 9:09pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6603 |
If your pedal currently has the long coiled spring fitted, you will need a later clutch pedal. Good mod though, done it to the soft top 1988 90 Td5 NAS soft top
2015 D90 XS SW |
19th Apr 2017 9:11pm |
Here you go. The search function is your friend:
http://www.defender2.net/forum/topic6616.h...spring+mod Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
20th Apr 2017 7:27am |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
I fitted a Britpart clutch assist thingy the other month, one of the better upgrades/mods i've done.
It's one of those 'why didn't I do this earlier' type situations. TD5 Defender 90 Discovery 3 HSE |
20th Apr 2017 11:37am |
I have checked and unfortunately have the old style clutch pedal
20th Apr 2017 8:12pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2215 |
It's dead easy to swap for the later type.
20th Apr 2017 10:36pm |
Thanks, do you change the pedal or the whole unit
21st Apr 2017 7:09am |
Would this do the job
http://www.ebay.co.uk/itm/Land-Rover-Defen...SwU8hY7pXZ |
21st Apr 2017 8:14am |
That would do it. Yup, swap the whole assembly out.
21st Apr 2017 9:11am |
Thanks Mo, would I need the modified spring for this unit, the spring on it kinda looks similiar to the uprated vesion .h
21st Apr 2017 9:33am |
No, these pedals are already fitted with the spring.
You don't need to change the clutch master cylinder over either, you can use your existing one. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
24th Apr 2017 1:55pm |
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 |
Did mine last weekend no spring on it at all, much better after and the tie wraps worked a dream
24th Apr 2017 7:44pm |
