![]() | Home > In Car Electronics > Misbehaving head unit |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5092 ![]() ![]() ![]() |
Is it tight in the dash - have you pulled it to make sure the cables are firmly connected? Mike
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
It's tight as in properly fitted yes and I have checked wiring - all ok
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Does the windscreen seal leak at all?
If it's just the Land Rover branded one (rather than the Alpine one), they're only about £20 on ebay, so not worth spending a lot of time on repairing. |
Yeah I had a look the other day. Looking like around £70 for a replacement. Just want to check it is my unit and not something else
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Mine did that for months couldn't fathom out what was wrong until I decided to take it out one day, inserted the keys and pulled it forward and the connectors fell out of the radio I had not pushed them in far enough for the "click" when they latched in. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
My current Td5 90 used to do that, only it would also coincide with the ABS modulator chattering, I found it was due to a loose earth connection on the bulkhead, (behind the coolant expansion bottle.)
Following your suggestions I went and checked the ISO plugs and the earth behind the coolant expansion tank but no no avail. Time for a new head unit I think
