![]() | Home > My Defender > Alan |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
I found it..
![]() Next job is the bumper needs painting.. do I stay black or go silver?............ |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
You may well be right, I don't know. But what you have look really great! Especially like the silver edge, makes a really nice touch. ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Thank you James..
I took my inspiration from this:- ![]() |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 ![]() ![]() |
Go sliver, it will match you wheels. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Wheels look great
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 294 ![]() ![]() |
Looking good
![]() 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1646 ![]() ![]() |
Looks fantastic! Worth the 'wrestle' as well imho!! ![]() |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10866 ![]() ![]() |
You sure made the right decision with the wheels, they are spot on
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
Looks a cracking 90.
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3651 ![]() ![]() ![]() |
your wheels look brill
![]() I hope everyone is well and your land rovers make you happy |
That looks great - certainly a lot shinier than mine!
If lifting the spare on and off is a challenge then consider fitting a Wolf Tuff Lift sling, which makes it a lot easier. Originally intended for the side mounted spares on military Wolfs, with a bit of modification to the bracket they can be adapted to fit a rear door mount. Here's one I fitted to a previous 110 some years ago: ![]() Click image to enlarge ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thank you everyone
![]() Whilst I am liking the new look what has impressed me a lot is that the drive has improved greatly with the larger diameter tyres.. much better in the gears and a more comfortable cruising speed, plus it seems less crashy and bumpy. LRA, thanks for those photo's, a great idea, I haven't come across a wolf one yet though Mantec do a copy which is around £80 ![]() Next jobs hopefully this week is to swap the front propshaft with a new one to hopefully cure a vibration and to finally fit the through centre pipe exhaust which is languishing in the corner of the garage... |
Well I made a start on removing the front prop... one nut is totally seized and already rounded off a bit before I started with it..
I've put some plus gas on the others and got them moving and the fourth one on the transfer box end is part way through being cut off.... ![]() hopefully tomorrow I might get it off... I have noticed also that the front prop is on back to front...Fingers crossed that is the source of the annoying vibration I get... only time and a prop swap will tell........ |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 ![]() ![]() ![]() |
Love the wheels great landy you have there
