Home > Maintenance & Modifications > One shot swivel grease when to top up?
Retrostu
United Kingdom 2005 Defender 90 Td5 XS CSW Java Black
Hopefully not a silly question but I last topped my 2005 TD5 90 swivel grease up in my swivel housing was a year ago as I noticed the ball was looking quite dull & grey, however now I have purchased my beloved landy back and no maintenance has been done (only cover 3k since I sold it) is it worth filling up again with one shot grease?.
I used to normally see a build of greasey crud around the ball but wondered if it does lose a little in time although I have never seen any on my drive or splattered underneath it either.
So Should they be shiny or a graphite grey colour normally?. It's more important to concentrate on what's ahead of you than what you have left behind.
This is what I keep watching to remind me why I own/keep my Defender. https://youtu.be/x4DZgOcgn1s
Post #617706 18th Apr 2017 3:15pm
Retrostu
Anyone? It's more important to concentrate on what's ahead of you than what you have left behind.
Post #617717 18th Apr 2017 3:44pm
dorsetsmith
remover filler plug check the level
Post #617722 18th Apr 2017 4:04pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Unscrew the filler plug and check the level with a makeshift dipstick. If I'm not mistaken the level should be at about the centre of the axle.
I think the state of the swivel balls only tells you something about the state of the swivel joint.
Regards,
Joris
Post #617727 18th Apr 2017 4:54pm
Retrostu
Thanks all for your help will make a dipstick up and check the level. It's more important to concentrate on what's ahead of you than what you have left behind.
Post #617735 18th Apr 2017 5:17pm
Retrostu
Well made up a make shift dipstick and it measured 2 inches in level in both sides so is this enough?. It's more important to concentrate on what's ahead of you than what you have left behind.
Post #617982 19th Apr 2017 7:47pm
the older oil filled used to be up to the top of the filler plug, so I can't see why the thicker grease should be any different.
I'd fill both sides up to the top if it were me.
Post #618008 19th Apr 2017 8:34pm
dorsetsmith
Post #618011 19th Apr 2017 8:39pm
