Home > Td5 > Engine oil - can I use my tractor oil?
hafman
My recently acquired 1999 Td5 needs an oil change. The Haynes Manual calls for SAE 5W/40. Looking through the Morris Lubricants website they recommend their Multivis CST SS 10W/40.
I already have copious quantities of Massey Ferguson MF Power HC Plus 10W/40 in my shed which I'd ideally like to use to a) save money and b) reduce the number of part used barrels in the shed.
What real world problems might I have if I used this oil?
TIA
Post #617625 18th Apr 2017 10:40am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
It's your motor, use what you like ..... Rolling Eyes
Technically - No. 10W viscosity is too thick at lower tempertures for the TD5 engine. Nearly all modern engines use a 5W lower rating now, some even lower [0W]
The first figure is the cold viscosity rate, the last figure the hot viscosity rate, so the lower the first figure the better, the higher the last figure the better [within reason lol, 75/85W is a bit OTT] Laughing
Stick to a 5W/40 [ or even better a 0W/40] Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #617632 18th Apr 2017 10:55am
hafman
Thanks Dave; I've gone for some Castrol EDGE Titanium FST Turbo Diesel 5W-40 instead Thumbs Up
Post #617663 18th Apr 2017 12:58pm
lightning
It won't harm the engine to use a 10w/40 instead of a 5w/40.
The main advantage l believe is fuel efficiency, a 5w/30 for instance will give lower friction loss in the engine and produce fractionally better MPG.
Unless you are planning a road trip to Alaska then the 10w/40 will be fine.
Post #618193 20th Apr 2017 7:34pm
Bluest
Just to say that I wouldn't trust the Morris Lubricants product selector. Despite them offering an engine oil that was BMW approved to the correct standard and grade, it recommended something entirely different for my BMW model. Very odd. 2007 110 TDCi Station Wagon XS
Post #618199 20th Apr 2017 7:49pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
Mf hc plus or hc extra as it's now know is a 10/40 transmission oil with an additive package for wet brakes and clutch packs i wouldn't be using it in my td5, Mf 10/40 premium engine oil would be fine though. Ps all MF oils are supplied by morris lubricants
Post #637404 13th Jul 2017 9:47pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Very specific in the owners handbook.
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #637491 14th Jul 2017 2:10pm
