Home > Maintenance & Modifications > Mobile Mechanic? Staffordshire/Shropshire/Cheshire area? |
Or perhaps a kind soul off the forum. Whereabouts on the border are you Jim?
14th Apr 2017 8:54pm |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 |
I'm in Loggerheads - near Market Drayton.
14th Apr 2017 9:16pm |
The other two hoses fitted but cannot get the smallest one seated. My hands are too big!
The OEM rubber hose has failed and I'm trying to fit the BAS silicon hose. Its already a really tight fit and I simply cant get it seated.
The Defender is dead in the water. I cant now get the hose on OR off. |
14th Apr 2017 9:22pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
Could you warm the hose up before fitting to make it more pliable? 1999 Defender TD5 110
15th Apr 2017 8:07am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 732 |
Thinking the same. Blast it with a hair dryer on hot - should soften and enable you to remove. I usually drop hoses in hot water before fitting. Both softens and lubricates.
15th Apr 2017 9:16am |
Maybe a thin smear of oil around the inside of the tube/pipe to aid insertion? 1999 Defender TD5 110
15th Apr 2017 9:26am |
I'll try to blast it with a hairdryer and see if that allows me to move it.
Then heat it up in hot water before trying to install it? |
15th Apr 2017 10:17am |
Hi Jim have you got it sorted yet??
15th Apr 2017 6:09pm |
Nope. I have reduced my knuckles to a red mess but otherwise no progress.
I can't get the hose back off to heat it in water. I did try a hairdryer and was able to move it slightly but nowhere near enough. Click image to enlarge |
15th Apr 2017 6:12pm |
Can you get hold of some silicone lubricant or even rapeseed oil would do just to get things lubricated enoug to easily twist and slide?!
15th Apr 2017 6:13pm |
I tried lots and lots of GT 85. The main problem is that there is no space to pull the hose.
I think it'll have to go to its favourite position here.... Click image to enlarge Then try and get it up to Pete Bell. Picked a terrible time as we're supposed to be taking the kids on holiday. Joys of Defender ownership! |
15th Apr 2017 6:19pm |
Well at least GT85 smells pretty good daft suggestion... How about one of the kids? If they are old enough of course.
Aren't NWS Land Rover pretty darned close to you? Market Drayton way. Would they pop out? |
15th Apr 2017 6:35pm |
Not used NWS before. Any good? Would you recommend them? I think i've been past them on the way to Whitchurch.
15th Apr 2017 6:53pm |
