Home > Td5 > Engine running rough and died
Page 1 of 3 123>
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
On the way home today, the engine was starting to run rough an losing power. I had to change down in gears to keep going. After a few km it gave up and then refused to start. Engine temperature was normal all the time and warning lights also behaved normally.
Luckily enough, another Defender stopped and gave me a tow all the way home. Excellent service. Thanks Rodolphe!
When I got home I tried to start it again and it started with some hesitation but running very rough (on some cylinders only) It was getting late and too cold to make further investigations I went in and poured a whisky Very Happy.
Tomorrow I have to figure out what the problem might be. Have you guys any ideas? Fuel starvation? I noticed a lot of soot in the exhaust pipe but no abnormal smoke. I will make a search on this site for similar problems.
Hans
Post #616622 13th Apr 2017 6:53pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Sounds like no fuel to me check that first! 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #616645 13th Apr 2017 7:42pm
Jim G
United Kingdom 1984 Defender 90 300 Tdi HT Stornoway Grey
Possible blocked fuel filter 1984 300TDi hardtop Stornoway Grey
1984 200TDi hardtop..... soon to be a V8 .. but which V8 ?
1974 DAF T244 4x4 wagon converted to a motorhome
1976 Jaguar XJC with supercharged engine
Post #616646 13th Apr 2017 7:48pm
grafty99
Short of the basics such as fuel filter and oil in loom - I would be investigating injector seals, fuel pump failure and crank sensor Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #616648 13th Apr 2017 7:50pm
HansT
Thanks for your advise guys.
This morning I did some further investigations.
- Turned the key on. Engine lights work normally but there is no sound from the fuel pump. The engine starts but with hesitation and runs very rough. Switch the engine off.
- Turned the key on and pressed the throttle five times. The engine goes to purging mode and the engine light starts flashing. But no sound from fuel pump. Switch of the key.
My conclusion is fuel pump fuse, relay or pump. What do you think? In the manual I have managed to locate the fuse but there is nothing about the relay. On the Internet there is a lot of confusing info about the location. Anyone knows for sure? My car is TD5 and MY 2004.
Thanks in advance!
Post #616740 14th Apr 2017 9:09am
dorsetsmith
relays driver seat box
Post #616757 14th Apr 2017 10:05am
HansT
Thanks dorsetsmith for those diagrams.
I checked the No 4 fuse and it was ok. However, My relay configuration was different with only three relays. Two yellow and one black (also different in shape).
Only the left relay was clicking when ignition was switched on. Swapping the yellow relays made no difference which to me indicate that they are ok.
No indication of oil in the loom. Both connections are dry (loom was replaced two years ago).
I also connected my Nanocom and it came up with two fault codes:
(2.8 ) Ambient pressure circuit (logged low)
(4.3 ) Coolant temperature circuit (logged high)
I deleted both fault codes and they did not return. The engine was idling very rough during this operation and I also looked at the cylinder readings on the Nanocom and they fluctuated quite a lot. However, after a while the engine started to run smoother (still idling) and the Nanocom cylinder readings did not show any big fluctuations. I did not dare to take it on a test run as I had not found any faults.
A final test o turning the ignition on still only gave a click from the left relay and no sound from the fuel pump. With this I left the Defender for today and will have another look tomorrow.
Have you guys any ideas of what is going on?
/Hans
Post #616811 14th Apr 2017 5:41pm
dorsetsmith
relay 1 and 2 only if you A/C fitted
relay 3 glow plug is your first yellow one working from foot well next yellow one is the main relay and black relay is fuel pump relay
Post #616817 14th Apr 2017 5:55pm
HansT
Thanks for that info dorsetsmith.
Is the function of the black fuel pump relay identical to the yellow glow plug relay and can they be swapped for testing purpose?
Do you have any thoughts about the fault codes?
/Hans
Post #616826 14th Apr 2017 6:11pm
dorsetsmith
With your Nanocom plug in can see engine RPM ?
Post #616829 14th Apr 2017 6:17pm
Check the engine sensors such as the MAF, does the TD5 have a MAP sensor too or is that just th Puma?
These things can cause all sorts.
Earthing can also. Idea No Guts, No Glory.
Post #616832 14th Apr 2017 6:24pm
HansT
Yes, the Nanocom also reads engine rpm.
Post #616834 14th Apr 2017 6:29pm
HansT
Yes, these sensors and earth connections are on my list but I have not got that far yet.
Post #616836 14th Apr 2017 6:34pm
mk1collector
The maf is easy to test. Just unplug it and see if the defender works better Ray
My build thread
Post #616846 14th Apr 2017 7:18pm
dorsetsmith
Post #616870 14th Apr 2017 8:37pm
Page 1 of 3 123>
